F652 upper baggage cover?
hoskinsb
Member
I am ready to make the radius cut on the upper baggage tunnel cover and could not find any reference on the plans whether the slight bend part of the cover goes up or down or does it even matter. Thanks for the help, Brent
Doesn't matter, and I've seen 'em both ways. FWIW, mine has the rolled/flanged edge on the bottom.
I'm putting the bent edge down and facing aft, figuring it may help to seal between the upper and lower halves, keeping drafts from coming from the aft fuselage into the cockpit.
