Cth6
Selling the UGB-16 Engine Monitor that I recently removed from my RV-9A. It is currently set up for
There is one minor issue with the gauge. Occasionally the lower right digit does not display the bottom center bar for the first min unit the unit warms up. So a block "8" will look like an "A" during start up. Outside of that everything works as expected.
If you are technically inclined and would like it, I will add in a Serial Data Logger that I created that logs the RS-232 stream from the UBG 16. You can dump it to a USB stick and format it as needed for places like Savvy.
Happy to bench power it via FaceTime if you would like to see it operate.
- 4 CHT/EGT
- OAT
- OIL Temp
