SmittysRV
I made the 2 F-996C reinforcement angles and drilled one hole on one end like the plans said, but when I tried to cleco the angle to the fuselage, the hole did not match the hole in the skin. So I had to make 2 more angles. This time I use the holes in the side skin to determine where the top and bottom holes go in the F-996C reinforcement angles. This picture shows how the actual holes in the angle are different from the holes the drawing. Note: My camera has a goofy wide angle lens which makes the angle piece look bigger than the drawing, but it's not.
Here's the measurement between the holes in the skin:
Here's the measurement between the holes on the drawing, using both the drawing lines and measurements on the drawing:
An finally, here's my question. If the holes on each end of the of the angle are not mark correctly, how can I be sure that measurements for the inner 3/16" holes are correct? These holes will have the bolts in them that hold the tank bracket in place.
Thanks for your help!
