F-9101 edge distance...
Michael Burbidge
After match drilling F-9101 to the skins and longerons some of the holes along the top of F-9101 do not have enough edge distance. I've noticed from other builder's websites that it looks like others had similar issue. But it is hard too tell from pictures. Did others find the edge distance here to be less than optimal?
michael
Did you take note of Section G-G on DWG 23 and radius the edges of the F-9101's to nest into the longerons? That should help bring the edges of the Gear Attach Web closer to the longerons.
