wirejock
Need manual advise please.
The manual says to check the F-902 bulkheads using a straight edge to verify the webs are parallel to each other and perpendicular to the fuse centerline.
Perpendicular which way?
What the heck are they talking about?
I can see measuring between them and ideally the measurement would be the same from top to bottom but I don't understand using a straight edge.
What do you use for a centerline reference?
