I have been trying to figure this out by looking in a lot of build logs and searching this form, but I cant find a answer to my question. I am trying to install my andar fuel valve bracket and the F-8113A mid cabin covers but the F-898-L Aux Longeron is not cooperating with the install. When I put the mid cabin covers in place and push it flush against the aux longeron it is lifted 1/4 to 3/8 of on inch above the F-8112 mid cabin support. the mid cabin cover has enough flex to be pushed flush to the support but I'm worried about how it will look once the screws are installed, and their is no way the fuel valve bracket will fit tight. the aux longeron is to rigged to bend in place (QB) and the only other solution I can come up with is to make a really long angled shim witch would be really hard since I don't have a mill. Am I missing something here? Did any one els run into this problem and donrt think this is the solution. Any help would be appreciated as I have been betting my head on this for two days now. sorry it is a 8A quick build drawing 68A
