HighSchoolBuilders
Hi!
I am at the stage to bolt the Mid Cabin Brace to the Center section. The pre drilled hole is clearly not size for an AN4 bolt, more like an undersize AN3 prepunch hole.
Before I go and drill the Mid Cabin Brace thru the spar, would like to check with other slow builders and see if they have the same issue. I can't find anything thru my current stage of build that require me to drill it to next size up to allow the AN4.
Many thanks!
Hank
Many thanks!
Hank
