rv8_builder
Active Member
The auxiliary longeron on DWG 66 doesn't show the center line for the rivets so I e-mailed Van's and was told that it should be midway between the outside of the vertex and the edge of the longeron.
The problem I have is that if I Cleco the longeron in position behind the F-802D-1 Landing Gear Box Plate with the bottom edge flush against the top edge of the F-802S-1 spacer, the line is not centered in the holes.
Am I missing something here or should the center line be moved toward the bottom edge of the longeron by 1/16
