briand
I have a 0.4 degree slant on this. What I think happened is when I installed the tailwheel mnt. it forced the bottom out. I drilled the side skins to the 812 first because I needed everything held straight and sturdy for tailwheel brkt. fit and install. The pc. of angle I had been using to hold the 812 had a bolt through the tooling hole that interfered with the tailwheel mnt..
Anyway my question is, can I shim it up when it comes time to install the V-S or will I run into a problem here?
I have a pic..
![](/proxy.php?image=http%3A%2F%2Fimg143.imageshack.us%2Fimg143%2F9121%2Fpicture152bg5.th.jpg&hash=93a838e05c6acd4983194ee5a8574f36)
I have a pic..
