F-8105 Brake Hose?
Joe
I'm ready to plumb the brake cylinders in my QB RV-8A and can't find the F-8105 Brake Hose referenced in the drawings. It's not in my inventory or parts cache as far as I can determine.
Is the F-8105 Brake Hose included with the quick build fuselage? Or does it come with the finish kit? Or is it an optional (extra cost) item and the standard part is made from nylon tubing? Or none of the above?
BTW, today I installed the infamous pop rivet static ports and I was pleasantly surprised how trivially easy it was to drive out the mandrels and connect the 1/8" ID tubing to them.
Joe
FF Kit
Joe,
I just picked up my firewall forward kit and those brake lines were in this kit. I am sure you can order them early if you want but more than likely they would just get in the way.
I think flying by this fall might happen!! Time will tell, I have learned that my ability to progress like I think is not alway correct.
Cheers.
