F-807-1 Bulkhead assembly - drawing error
Mark Albery
With luck I'll save someone else from the same little mistake that I've just made.
Dwg 70 (date 12/14/05) shows F-807A-R-1 forward of F-807A-L-1 where they overlap. That is wrong. Dwg 69 shows the correct orientation.
The mid-section bottom skins have a slight offset to the line of rivet holes which will only line up with the correct overlap. Only 3 rivets to redo, but annoying none the less.
Happy building.
Mark
Same thing
Wished I had seen your post first, but went ahead per DWG 70 which resulted in mis-matched\figure 8 holes on three tabs on the bottom outside flanges on both the right and left bulkheads. Van's said I could redrill and add a couple of rivets each side of the figure 8s or they would send new bulkheads at no charge since they agreed it is a problem once I pointed them to the two different drawings.
New bulkheads at no charge are on the way.
