Hi All,
I'm in the process of finally installing my F-799 wing root fairings and have run into a fit problem that I can't find addressed elsewhere. When I riveted my tank I used the fay sealing method where you assemble the entire tank with clecoes then come back the next day and rivet it. I also wet riveted all the lower fuselage skins on my aircraft and noticed that if you set the rivets when the fay seal is still wet a lot more sealant squeezes out. Thus I suspect that the increased thickness in the tank has increased the radius slightly, which is making my fairing fit really tightly. As you can see in the pic below, this is pulling it in substantially at the root. To fit the fairing (since instructions are almost non existent) I started by drilling and clecoing the most aft hole on the bottom side then drilling and dimpling for the existing tank screw right near this for a bit more purchase, then pulled the fairing up and around the leading edge and clecoing the 3/32 holes along the wing walk doubler. My plan at this stage is to relieve the 3/32" holes in the fairing at the wing walk doubled to an "out of round" state until the fairing becomes square again, then drill the leading edge holes along the line 1/4" in from the edge I have already marked, then finally open the wing walk holes to full size and hope this works. Has anyone run into this problem before and can they provide any advice so that I don't have to rely on hope and blind luck?
Tom.
Tom.
![rbfafs.jpg](/proxy.php?image=http%3A%2F%2Fi65.tinypic.com%2Frbfafs.jpg&hash=4bece88f47de50a3c132b35669676e94)
