Desert Rat
So I'm to the step where you temporarily fit this. It's already drilled, so there isn't anything do to it except debur, but I've got a quick question for the collective.
It appears that the aft vertical flange goes fwd of the lower baggage panel, right?
Even without that panel in place, it's wanting to sit too far fwd by about 1/16" for the holes common to the floor and inner rib nut plates to line up. It's going to be .025" worse once I get the baggage panel in there under it.
Has anybody else had a fit problem with this?
