s10sakota
(Title should read "bushing" holes)
I have very carefully measured the two holes for the plastic bushings that are to installed in the F-704B center section bulkhead.
In the pic below, you can see the pilot hole I drilled. Then I drew a 5/8" diameter circle around the hole as this is the size hole that is to be step-drilled.
But notice how close it will be to the rivet hole. Is this OK? This is exactly what the plans are calling for, but it seems too close to the rivet hole to me.
![](/proxy.php?image=http%3A%2F%2Fi108.photobucket.com%2Falbums%2Fn7%2Fmarky613%2FForum%2520Pics%2Fhole_zps611f2b17.png&hash=df29e7e4e5b80402c4eaa62334f5953b)
