jsharkey
The outboard Cockpit Floor Angle to Wing Spar brackets, part number F-699 shown at the top left of drawing 46 do not come close to lining up with the nearest 3/16" bolts on the lower cap of the wing spar on my RV6. In fact the vertical leg of the floor angle pretty much aligns with the center of the nearest bolt on both sides.
Has anyone else come across this problem due to build errors or otherwise, and if so how did you get around it?
Jim Sharkey
RV6 - At Airport Working on Final Details
Jim Sharkey
