mototopo
Hi all,
after a long time away from the project I'm again at work.
I'm working on the center fuselage section and I need some advice on the correct shaping of the F-623 corner rib that goes in the baggage compartment.
If I correctly understand the drawings, I need to cut both ends of the rib to fit it with its flanges aligned with the bottom skin edge.
On the forward end, it need to be shortened to sit flush with the baggage bulkhead flange. Am I correct?
I'd greatly appreciate a few pictures to have a good idea of what to do.
Thank you very much!
