Regarding the two holes that are required to be drilled in the F-445 Flap Bearing Block:
Wondering if someone can explain why the plans and construction manual have us drill a #10 hole for the AN3 bolt. Seems to me, drilling a #12 hole would be the appropriate diameter to accommodate an AN3 Bolt? (#10 hole will obviously result in a sloppy/loose fit?)
Thank you in advance for your replies!
Mike
RV8
Mike
RV8
