I'm just assembling the control stick pushrods (32-05), and am unsure how tight the locknuts (AN316-4R) should be. The Standard Aircraft Handbook says 30-40 in.lb torque for AN316 nuts, but does that still apply in this case where the threaded portion of the bearing is screwed into the tapped aluminium tube?
Has anyone used threadlocker on the fittings?
Advice appreciated.
Advice appreciated.
