MechaSteve
Active Member
The opposite to the question of using blind rivets to avoid driving solid rivets:
Can I use all solid rivets, instead of a mix of solid and blind?
In the KAI, the rivet call-outs for the Tail Bulkhead (F-1211) show using solid rivets for the more "outer" rivets (the ones at the top and bottom of the bulkhead), and blind rivets for about 10 of the inner rivets.
Specifically I am talking about the ones used to secure the nutplates and the trim pivot brackets.
It looks like the blind rivets are used to meet the "just simple hand tools" promise by not requiring any solid rivets that cannot be reached with a 1.5" yoke squeezer. However, the counterbalance access hole in the middle of the bulkhead is large enough to allow a squeezer to be used from inside out.
Does using solid rivets like this alter from the KAI in a meaningful way?
Has anyone else tried the same, and run into issues I am not seeing?
