Gang,
I've searched everyway I know how in the forums and don't see where anyone else has encountered this, so here goes...
Page 21-09 Step 3 says to "slide the BUSHING AL .197x.313 x 1.954 into the F-1204M Roller". After smoothing the edges of the Bushing, I had to DRIVE it into the Roller using wood blocks. Anyone else have similar experience?
Next it says to install them between the bulkheads and secure using the AN3-24A bolt into the nutplate.
No problem there, but it makes me wonder...
1) If the bushing is truly supposed to "slide" into the Roller, then I would expect that the AN24A bolt should be torqued into the nutplate (approx 24 in-lb) resulting in the Bushing being tight between the Bulkheads and the Roller spins on the Bushing.
2) Or, my Bushing and Roller are fine (interence fit) thus the Bushing/Roller combo spins on the AN24A "Axle" (with some light lube?) and the bolt should be left just loose enough to allow the bushing to spin. In this case seems like washers would be needed to avoid the spinning bushing from wearing into the bulkheads.
I've checked and rechecked the dimensions, even ordered new Bushings from Van's and compared with mine (they're the same).
So guys and gals, am I missing something? or just trying to make it too hard?
Will appreciate any ideas, suggestions, or answers you've gotten from Van's.
Thanks!
Dave
RV-12 #121.
Wings and Emp hanging in the Garage.
Fuse on the work table.
As always, more tools on order!
Thanks!
Dave
RV-12 #121.
