Did anyone else have trouble with the bearings becoming tight and not moving freely when the F-01450 bearing brackets are assembled? These are the brackets that hold bearings for the CS-00006 control column assembly.
The bearings move freely before assembly. Once it's all riveted together, it appears the bracket distorts the bearing casing slightly.
It may also be worth mentioning that the rivets Vans specifies are _way_ too long.
Did anyone else run into this problem or have solutions to this?
