F-01411C Coating
md9680
Friend
How have people been removing whatever the coating is on the F-01411C Horizontal Stab Attach Bars so that they can be primed?
Thanks.
MD
I removed the clear plastic film (I think that part had it) and then hit it with a scotch-brite flap wheel chucked in a drill press.
_Alex
Thanks for the reply, Alex. Mine doesn't appear to be clear plastic but I'll try to remove whatever it is -- your way is as good as any other.
-Mike
They did indeed have a clear plastic film but underneath they appear to be anodized a dark gray. I had already deburred the bare aluminum edges so I guess I can just prime them now.
As others have confirmed, it comes with a clear plastic which becomes a lot more noticeable when you start deburring the edges. Since I primed everything, I gave it a good treatments and then primed.
Any time I had vinyl that didn't want to come off, I stuck a bit of gorilla tape on it for a few seconds and then it would pull the vinyl right off.
