Eyeball lights wiring
RV8Squaz
For those of you that mounted the eyeball map lights in the holes of the rollbar weldment... How did you route the wires back to the panel so they are out of sight? Can't go fwd because of the instrument panel itself. I was thinking about drilling a small hole in the tubing and another on the bottom plate that falls within the tubing circumference and down between the 804A and 804B. Any other ideas or pictures?
Thank you!
Jerry
