dhmoose
I purchased the eyeball lights from Stein and I would like to mount them on the slanted area of the forward portion of the Aerosport overhead console. That said, they seem like they would be in the way of the headset rack. So, I positioned everything and realized that it might be more ideal to mount the eyeball from the inside of the console instead of the outside as the instructions have you do. Has anyone tried this? It would look like a 3/4" hole with only the eyeball itself peaking through. You wouldn't see the black rim and it looks as though it wouldn't limit the angles that the eyeball can swivel to.
Check out the pics on the top link of my build log (Then ignore the fact that my log is 6 months behind and I am shamelessly using it to show the pics of my current dilemma! )
www.mykitlog.com/dhmoose
Thoughts?
David
Thoughts?
David
