How far is the longest leg around the world?
I'm just curious if it would be at all practical to put an extra 20 gallon tank in the 12? One thought would be to make the passenger seat removable so that you could put an extra tank there for those long x-country solo flights. Any ideas on this?
to increase it's capacity. The way it looks now you should be able to at lest doubly it to take up all of the back baggage area http://www.airplanefactory.co.za/world/default.asp[/url]
Does this mean that in an unmodified plane the CofG is also out of range with a 180lb pilot and 2 gallons of fuel? If so how much fuel is effectively unuseable, because it is acting as ballast?
My initial idea was to make the passenger seat removable and replace it with an additional 20 gal. tank for long solo flights, and this seems doable. But now let me take it a step further. My calculations show that if I leave the passenger seat in place and take my wife along, we could stow an additional 20 gallons of fuel and still be within gross weight limits with 25 pounds to spare. SO with that in mind, I'm wondering if a custom 40 gal. tank could be designed to fit snug behind the seats so as to not violate CG limits. If this is possible, maybe that custom tank could be a molded material that is not prone to leakage, as seems to be a concern on the "fuel tank woes" thread. More thoughts on this?
... probably no less comfortable than he is on similar modifications to any of his planes...
Tom, you mean like these?A good friend of mine, who has enjoyed many pleasant hours in a TR-2, which is a late model Grumman American Yankee, has a marvelous idea. He claims that the RV-12 wing is the perfect candidate for fuel cylinders, similar to the TR-2, which could occupy the nice voids that the wing rib lightening holes provide. It would likely be very conceivable to carry up to 20 gal. in each of these wings, with just a little engineering. Any volunteers?? Yes, wing removal becomes more of a project, but surveys have indicated that the majority of us RV-12 guys don't plan of doing that on a daily basis.
Any Comments??
Tom
That would be San Francisco to Honolulu which is about 2400 statue miles. Head winds most of the time.
Best regards,
Vern
If that is the longest leg and there are headwinds you should go the other direction![]()
Any Comments??
Tom
The RV-12 MUST be registered as experimental. Modifications to Experimental-LSA have to be done after certification, whereas Experimental-Amateur Built can be modified at any time. By "Go Experimental", I assume E-AB was meant, not E-LSA.I will and Go Experimental or Build two sets of wings
The RV-12 wings are probably strong enough to carry fuel internally while flying. If the wing tanks are full during a hard landing, the inertia of falling fuel will impose high negative-G loads on the spar-fuselage junction. An engineer should be consulted to determine if the RV-12 is strong enough to carry these loads.
Joe
There are headwinds in both directions![]()
Joe
but there is only one longest leg. plan that leg to have the tailwinds
You could try CarolAnn and Carol's route around the world in a Mooney:
http://www.alsworldflight.com/
The home stretch from Cape Verde to Miami was a bit long too.
