I have a great mount for my gopro attaching it to my tie down. The problem is the batteries are crapola as far as lasting more than 30 min. If I mount the camera in the cockpit I can use an external battery pack. Under the wing - I need to figure that out. https://www.youtube.com/watch?v=0TewJjnnrMI
Dont be too harsh on the landings - this was my first solo!
My idea is to mount the battery pack on the inside of the inspection panel and run the charging cable out a small hole. Has anyone done this or figured out how to mount a battery pack? It is not an area you want something coming loose, so I am looking for ideas. My first idea is to make a case from Kydex and rivet or bolt it on. Maybe an aluminum box with hinge door and secure hasp?
I cant be the first frustrated with the battery life so what have you guys done?
