Need advice about remote mount transponder (GTX23-ES). I plan to put it behind the baggage bulkhead but the Garmin harness is not long enough. The mounting rack takes a high density (3 row) Dsub connector. I can cut the Garmin cable and use two pairs of standard density Dsubs to make an extension cord or I can use one pair of high density connectors and not cut the Garmin cord. I have not worked with the high density connectors but assume they require a special crimper and seem to have smaller pins. How have others solved this problem?
