I have about 75 hours on my RV-10, and smell exhaust when in slow flight, on decent, and at procedure speeds (120 kts). I also have a CO detector that goes off at any flight condition with vents closed and heat off after about 15 minutes. Opening vents, or turning on heat stops the alarm as air circulates through the cabin. I have a standard Van's setup, including the exhaust system, that is not modified in any way. The pipes exit per the plans, and look like others I have seen online, at Osh, etc.
Has anyone else had issues with exhaust in the RV-10? If so, what did you do to fix?
Aaron
Aaron
