az_gila
I just installed the Vans exhaust hangar kit, but as I stepped back and looked I found the cross tube blocked the mixture cable path.
On a -6A, standard Vetterman cross over system with the newer formed ball joints, I found the 9 inch heat muff on the right side restricted how far forward I can position the hanger clamps.
The mixture cable exit on the firewall is very low, the O-360-A1A carb control cable bracket is also pretty low, and the nose gear support is in the middle. All of these items are conspiring against me.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This solution, though it does involve attachment to the airframe and not the engine would be an easy fix.
A 2011 posting here and one of Vetterman's recommendations.
Since it's been 4 years since this posting -
http://www.vansairforce.com/community/showpost.php?p=572206&postcount=1
Do any of you have a good operational experience with this arrangement?
Thanks... frustrated in Tucson...
![exhaust%252520mount%2525202011%2525201.jpg](/proxy.php?image=https%3A%2F%2Flh4.googleusercontent.com%2F-Hb3c-c_C4-M%2FTlrgqbAYQrI%2FAAAAAAAABkU%2F0m4PZq9sBqs%2Fs800%2Fexhaust%25252520mount%252525202011%252525201.jpg&hash=09b9be2dd1ece3ad7dc1753362b6e967)
