GatorAviator
I'm New Here
I've seen other threads concerning custom tapered wings, but has anyone seriously considered putting an EVO wing on an RV-7 or -6? It seems it would be a fairly simple mod. Input?
Nope, probably not.Are the spar stubs long enough for a -6? If so....![]()
And as I heard, the performance of the prototype was.....underwhelming.Also butt ugly
Regards,
... The EVO wings are a piece of aluminum art, but they are very, very heavy. They were built to Part 23 standards and, in my opinion, are over-engineered for the airframe. Also, they would be very difficult to build by your average garage guy since they require a complex metal jig. The wing tapers (both front edge and aft edge), is twisted (each rib at a different angle of attack), and each rib has a different chord and different thickness as it moves out from the root. I suppose that if you get any of this out of perfect alignment, I'm guessing your performance will be significantly affected. If that wasn't enough, the ailerons are cupped to improve performance....
THIS particular wing IS VERY HEAVY, and much heavier than the hershey-bar wing it replaced.
