I got a NO OIL PRESSURE alarm on my first flight after repairing the plane after its takeoff stall. I landed immediatelyl
The alarm was false. The Dynon D-180 acted differently if turned off then on. Indications vary and with no fuel pump on the fuel pressure shows over 85psi, for example. Turning on the GPS makes makes oil temperature vary from 1 to 40-degrees F, sometime jumping to oveer 100-degrees F.
Oil temp if steady shows 13 or 14-degrees F, temp in hangar was 60-degrees.
Turning on autopilot makes the MAP jump to 99.8-inches, then it drops to zero, sometime steady, sometime not.
Pulling fuse for EFIS makes oil temperature vary from 7-degrees F to 35-degrees and it keeps jumping between these numbers.
Ground from power panel to airframe = zero ohms.
Battery ground to airframe solid, zero ohms.
All connections and their pins fully engaged and tight.
Dynon upgraded my software to version 5.4 which I had not yet done, and naturally destroyed all my settings. Now the Dynon cannot detect the OAT or the magnetometer either.
God ! I wish I had simple, reliable, trouble free, stream gauges.
I asked Van's for help: Dynon more or less said the rest is up to Van's. We'll see what happens.
JohnF
JohnF
