I have had a lot of folks write to me and ask how I configure the displays on my GRT EFIS-equipped plane, and have always had to resort to written descriptions....well, I finally realized that a picture is worth a thousand words, so here I am, level at 8500', southbound, about 118 miles north of Neosho, MO. Just another day in (actually, out of) the "office".....
This is how I have seemed to end up when in cruise mode, using the new systems monitoring pages that came in v29. I have stated many times before that I rarely used the split-screen modes, but have come to like the new systems split, with systems on the left, and the map on the right 2/3rds. With one button push, I can go back to full-screen systems and engine data, which is nice if you are flying a complex departure, and trying to get things leaned out at the same time.
Generally, I leave the bottom DU on the full-screen systems page during departure and climb, because I always have a map on the GNS 430 anyway. I go to a map page on the bottom DU (or now, the split screen map/systems), once I am in cruise.
The greatest addition has been the Garmin 396 over on the right. This gives me two full-performance, database-equipped navigators, so that I can be flying one plan while "what-if-ing" with the other. I will generally put a multi-waypoint plan into the 430, following airways or fixes, and a direct routing into the 396. That way, I can see if I can take shortcuts. Since I have weather on the 396, I can plan diversions around rain or other nasties on that, and then manually transfer the new plan over to the main unit when I am ready. The autopilot will fly in heading hold on it's own, fly heading as commanded on the DU, or follow Nav from the EFIS or direct from the GNS. You just have to make sure you watch the indications so you know what it's doing!
Once I tried and got hooked on XM weather, I called GRT to get the XM box for the EFIS, but they are currently in a redesign, so I picked up the 396 as an interim solution. Now, I am so used to having it, I might end up with both! You can never have to many displays, or look at to many plans at one time.....
I guess the bottom line to this post was to say that if you have a dual-screen plus a GNS 430, you really don't have a problem with finding a place to put your map!
Paul
![img0364az0.jpg](/proxy.php?image=http%3A%2F%2Fimg101.imageshack.us%2Fimg101%2F2386%2Fimg0364az0.jpg&hash=bb8469d19f407e2b86cad51ffa75154f)
Paul
