acam37
We now have almost 50 hours on our -4. While in cruise we've noticed a slight vibration that seems to be coming from the engine. It is best described as when you lean back to the point the engine starts running rough. The vibration is the same at different throttle settings and mixtures. I've never flown another -4 so I dont know if its normal. Engine parameters are all normal. The Lord mounts are not the same part number as Vans sells so that's one area that might be the culprit. The prop is a Catto three blade purchased used. Any suggestions on what else to check?
