I wanted to have a convenient working height for installing the fiberglass cooling shroud so I made an engine stand out of the Rotax crate. I removed the sides of the crate from the bottom where the engine was mounted then used some of the 2x4's from the kits and simply screwed them to the sides of the crate to make a stand about 30" high. We lifted the crate bottom with the engine bolted to it and placed it on top of the sides, now with legs, and screwed the four corners of the top to the top of the legs. It made a real sturdy work table.
