ZU-RVFour
Active Member
I have posted in gen area as well as it seems not many -4's comment here.
There are only 5 RV4's flying in South Africa and none with my setup, so I would appreciate some comments from across the pond.
I have been drilling holes in the sky at 175+kts for 3 years in my RV4 (IO-360 with CS Hartzel prop) all over Southern Africa. Range is then around 3.5hrs on the 32 gal tanks, but it pretty much at full bore 21"MP, 2500RPM (red line 2700) and around 9gals/hr. Usually at around 7000 ft (which is 1500" to 2000' AGL)
Recently I spoke to a RV7 driver with 42 gal tanks and O-360 who tells me he gets 7.5hrs endurance. Is this possible? It then transpires he cruises at 18" and 2200RPM. Kinda defeats the object of having RV for me (Speed).
Question is thus - what is your preferred cruise setting and why?
(RV model, Eng, Prop, Rpm, MP, Fuel flow and speed)
Thanks in advance.
Cheers
George
ZU-RVF "The Meercat"
IO-360 RV4.
PS
If been covered before please ignore and point me in right direction...![]()
