IO-540C4B5 available
There is an IO-540C4B5 narrow-deck available from globalparts.com, has 1100 hrs since OH and is off a recently flying aircraft, $9000. I forget the TTSN, think it was in the 5500hr range, which is a bit higher than some might like but I see no problem with it. I bought the other engine off this airplane, which is a freighter Aztec getting parted out. Logs looked good from the part that I saw, only catch is it has the cylinder AD requiring 50-hr inspections. You could keep it as-is and deal with that as you will, or do a top overhaul (my choice on the one I bought).
780-458-2801- Ask for Paul, tell him Dwight sent you. He took good care of me.
C4B5 is almost identical to the D4A5 except running at lower RPM, and should be no problem to increase the RPM to the D4A5 2700 rpm level.
Dwight
