Mark Burns
I'm fitting the cowling and I didn't realize until now how far the engine is offset to the left side. It's about 3/4" at the rear of the engine. The engine is angled to the right so the prop winds up in the center.
I know the vertical stablizer is offset, so I thought the engine would be centered and straight. I knew the carb and airbox favored the left side but I didn't put 2 & 2 together until now. Why isn't there more talk about this? I can't find anything in the archives. Do builders just not notice it?
The rocker box cover for #2 cylinder is about 5/8" from the cowl.
It's way closer than #1 that is more forward and getting into the inward curve of the cowl sides.
I sort of freaked out when I noticed it. I thought I had a bad engine mount.
Mark
Mark
