RFSchaller
I've got 32 trouble free hours on my 912ULS, but today during run up I had a loud screeching noise at about 3100 RPM. It disappears above and below that RPM, but it is consistent and persists at that RPM. There is no evidence of rubbing between the cowling and spinner. Has anybody experienced this? Could it be gearbox related? I don't get any engine vibration, just the high pitched screech similar to what it sounds like when you twist the PVC cap on a PVC pipe. I used Mobil 1 oil the first 25 hours and then switched to AV-9 from California Power Systems.
