engine mounts
Dennis Madden
Active Member
Folks,
finishing up my oil pump A/D, oil filter install and a bunch of other clean up on my purchased RV-4. Went to hang the motor back on and could not remember how the motor mounts went on... Does anyone have, or can you point me to..a picture of what it looks like? The order and orientation of all the hardware back there? Thanks in advance.
Almost done...
The engine mount will only go one way.
If you mean the isolators, you put the one with the sandwiched plate on the side supporting the weight.
Forward of the engine ear on the top ones, behind the ears on the bottom ones.
Best
engine mount bolts
Don't forget about the 4 engine mount bolts.
2 are longer, 2 are shorter.
Rich
Best
Thats what I was looking for. Thanks kahuna
DM
