Engine Mounts
Mark Cigal
Active Member
Sponsor
Greetings all ! Well after 230 hours of pure enjoyment in my RV8, I've noticed
my engine mounts have begun to sag quite a bit. I'm wondering what the best
and easiest way to cure this problem is. Have thought of swapping the lower
mounts with the uppers or putting in shims to raise the engine. How has
everyone else solved this problem ?
which ones
which mounts did you use. lord or VIP's
oh and i would do the washer install as well.
