MWH265
Working with my mechanic I had to pull the bottom engine mount bolts to correct a washer configurement. I have Barry mounts on an IO-360 angle valve engine. The bolts on the engine mount have castle nuts with cotter pins. Would it be ok to replace the castle nuts with locknuts to avoid the task of lining up and properly installing the cotter pins in a very difficult location?
Mike
Mike
