dick seiders
I know this has been up on the thread before, and after checking my washer to rubber mount clearance at bottom end at that time did not see a problem. However that was some time ago and following an oil/filter change yesterday I noticed some smoke residue on my firewall fwd checkout. The smoke came from the 1/8 fender washer rubbing the lower engine mount tube on the right side. I looked at the left side and while no sooty residue evident there is some small contact between the washer and tube. I am in process of relieving the washers via grinding, and will have to sand and re finish the washers as well as the two engine mount tubes. Nothing really new here, but the problem has shown up at 90+ hrs, after not being obvious earlier so this notice. No problem damage at this time, but take a look if you haven't as this type of rubbing interference could cause engine mount failure eventually. Not a pleasent thought.
Dick Seiders
Dick Seiders
