Am I missing something???
I am trying to get my engine mount mounted. I am having trouble with interference with the F893 L&R ribs that outline the side of the cooling ramp. The most forward parts of the 893's are interfering with the engine mount tubes that run between those two inner mounting holes (the ones that you drill into the firewall near the cooling ramp) and the nose gear leg holder. Basically, I can't push the bottom of the mount down flush against the firewall.
The instructions say to trim that fold over flap from the cooling ramp as necessary. However, that is not a problem. If I have to take off the corners of the 893's, there is a rivet there will probably have to come out.
Thanks in advance,
Thanks in advance,
