I probably know enough about Lycoming engines to make wild accusations and speculations. So I'm looking for some clarity.
I've got an IO-320-B1A engine, it's a Dynafocal 2 mount. Another on the forum said that Van's didn't want to sell a mount for their project, which surprised me. So I dropped off an email to Van's. The answer was, they'll sell a Dyna 2 mount, but it's special order. All well and fine by me, but then they said they were more concerned about the forward facing induction sump. ?!?!
The B1A was off a Comanche twin, and has a rear facing induction sump. My belief is that with a 9A, there is no way I'm getting the rear induction to work since I think the nose gear weldment is right there. So I was planning on going with a cold air induction kit that makes the sump forward facing induction.
1) Are there no RV-9's with a forward facing sump? I'd really like to avoid the snorkel if possible.
2) What's the exhaust got to do with where the air intake on the sump is? I'm planning on using a Vetterman exhaust, but still this confuses me greatly.
Anyone out there that can share some tips. Even better if any of you out there are flying a B1A engine?
Thanks as always, Happy New Year!
The mount is not a problem - it is a D2 engine I believe which is special order though.
You will have other issues with a forward facing sump - we do not have an
exhaust that will work for it on a 320, and the FAB will be hard to modify and
fit. A vertical induction sump would be easier: I'd use that if you don't yet
have the horizontal sump.
Vans
