I have spent the last two hours trying to use the VAF search and Google to find the answers to this question with no results except frustration. I have a IO 360 with a A/C engine driven fuel pump that I can?t get the restrictor fitting for the fuel pressure sending unit installed because the position of the output is too close to the engine and engine mount. I have tried to take the pump apart and re-clock the ports but any position I try will not allow the correct orientation. Can I reorientation the in and out ports on the fuel pump? The picture doesn?t show it but the restrictor fitting will not go on the pump. The picture shows the only way I can get the pump together. I have had the pump apart about ten times trying to get the rite orientation so any help is appreciated.
![dq3wgi.jpg](/proxy.php?image=http%3A%2F%2Fi53.tinypic.com%2Fdq3wgi.jpg&hash=e0618e6575209b06eaa7e5d5c29a749f)
