SeanB
Hello,
I'm about to make the longitudinal/split line for the upper and lower cowl halves to match. Front ring is pretty good and have trimmed the aft lines at the firewall.
Question: Is the split line supposed to be parallel to the longerons of the cabin area? Or...just go with a line from the intakes split, then aft to a point that satisfies both sides to match?
Thank you!
Thank you!
