Engine Cowl for RV-4, older type
Remteck
Active Member
Does anyone has a used older type (polyester resin/white gel coat) Engine Cowl for RV-4? Any condition (used, broken, only one half, ...) is good as long as I can duplicate the cooling air intakes.
The previous owner of my RV-4 cut it off because he wanted to installed round intakes and a pressure plenium. Since the cowling has been fitted, the baffling was almost completed and I don't have the time to go his route; I want to repair my cowling as per original but don't have enough material left to figure out the inlet area. (I think it's around 52 square in)
Did you get what you need?
I have an old, used RV4 cowl taking up space in my hangar. Ironically, I'm replacing it with a round inlet cowl!
M
