Hi all, this is just to report my progress.
After two and a half days of hard work I am happy with the end result.
I know everyone has his/her own secret recipe, but I would like to share mine with the VAF family.
1) Thoroughly clean the cowl with soap and water.
2) Paint on resin, hardener thinned with acetone as per Vans instructions.
3) Lightly sand down. At this stage you will think - I don't have any pinholes and weaves. What are these guys talking about?
4) Clean properly and apply a healthy coat of primer. Here in SA we use a @K filler primer by Plascon.
5) Flat the primer with 220 to 360 grit paper by hand or wit an orbital sander.
6) Here is an important step. Take your air nozzle and thoroughly blow off all the dust going slowly and not missing any part. To your amazement you will now see thousands of holes and weave marks. Don't panic. You have now actually blown clean all the holes.
7) Use a thin spot putty ( here I have used Standox 1k body fine ) and a carpet knife blade or similar to really try and squeeze the putty into the holes. The idea is not to have lumps of putty that you will battle to sand off again.
7) Flat again by hand or orbital sander.
8) Blow dust out of all the holes again - don't rush and do a thorough job. I found that this part is best done outside in direct sunlight ( or if you have spot light it should be ok ) in order to turn the cowl around and at all possible angles. Just when you think you've got all the little *******s, another few will show up at another angle.
9) Apply thin body putty again with your blade.
10) Flat again - this time with a 400 grit paper and do it with a soft sanding block by hand.
11) Clean and degrease again.
12) Apply your final paint.
The end result came out quite well and was confirmed by the usual number of "inspectors"
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
one have while you are building. See the picture below.
Hopefully this will help one or two fellow builders out there.
Jan.
