While inspecting after an oil change I noticed the plastic covering protecting the control cables (throttle and mixture) was pulling back or shrinking a bit (3/8"). I don't think it's from exhaust heat because it's worst on the inside away from the exhaust system. I'm wandering if this an unsafe situation or can heatshrink be applied to protect the cables? Grounded until I get a solid responce.
Ron
Ron
