Harold Lanfear
After much searching of the plans, I finally found the locations, etc for the throttle, mixture and prop cables through the gear tower - but only after I got some no-so-subtle clues (like "see drw 30") from the VAF archives.
I still have this question; when I cut the 'sort of' trianglular hole (from archives; much thanks guys for the posts, as I would not have figured that one out for myself versus the plain circle in the plans) for the control cables; did any of you provide any type of chafe protection.
Has anbody drilled separate holes and used grommets; or is the extra space needed to thread the cables through the tower?
Thanks much,
Thanks much,
